Objeto lightingOutput
Defines a standardized object whose properties represent the externally visible characteristics of a lighting output and includes dedicated functionality specific to lighting control that would otherwise require explicit programming. The lighting output is analog in nature. The physical output level, or non-normalized range, is specified as the linearized percentage (0..100%) of the possible light output range with 0.0% being off, 1.0% being dimmest, and 100.0% being brightest. The actual range represents the subset of physical output levels defined by Min_Actual_Value and Max_Actual_Value (or 1.0 to 100.0% if these properties are not present). The normalized range is always 0.0 to 100.0% where 1.0% = bottom of the actual range and 100.0% = top of the actual range. All 0.0% to 100.0% properties of the Lighting Output object shall use the normalized range except for Min_Actual_Value and Max_Actual_Value. If Min_Actual_Value and Max_Actual_Value are not present, then the normalized and non-normalized ranges shall be the same.
Objetos do tipo lightingOutput possuem as seguintes propriedades:
•blinkWarnEnable
•commandTimeArray
•covIncrement
•currentCommandPriority
•defaultFadeTime
•defaultRampRate
•defaultStepIncrement
•description
•egressActive
•egressTime
•feedbackValue
•inProgress
•instantaneousPower
•lastCommandTime
•lightingCommand
•lightingCommandDefaultPriority
•maxActualValue
•minActualValue
•objectIdentifier
•objectName
•objectType
•outOfService
•power
•presentValue
•priorityArray
•profileLocation
•profileName
•propertyList
•reliability
•reliabilityEvaluationInhibit
•relinquishDefault
•statusFlags
•tags
•trackingValue
•transition
•valueSource
•valueSourceArray
