lightingOutput.blinkWarnEnable |
Specifies whether a blink-warn is executed (TRUE) or not (FALSE) when a WARN, WARN_RELINQUISH, or WARN_OFF command is written to the Lighting_Command property or one of the special values is written to the Present_Value. When this property is FALSE and a warn operation is written, a blink-warn notification shall not occur, and the effect of the operation shall occur immediately without an egress delay.
A propriedade blinkWarnEnable do objeto lightingOutput pode ser lida e escrita utilizando um tag normal (IOTag).
lightingOutput-<endereçoDoObjeto>.blinkWarnEnable |
<tipo> = 54 |
<propriedade> = 373 |
