lightingOutput.lightingCommandDefaultPriority |
Specifies a write priority of 1 to 16 that indicates the element of the Priority_Array controlled by the Lighting_Command property when the BACnetLightingCommand priority field is absent. The priority value 6 shall not be used for this property.
A propriedade lightingCommandDefaultPriority do objeto lightingOutput pode ser lida e escrita utilizando um tag normal (IOTag).
lightingOutput-<endereçoDoObjeto>.lightingCommandDefaultPriority |
<tipo> = 54 |
<propriedade> = 381 |
