lightingOutput.defaultRampRate |
Indicates the rate in percent-per-second at which changes to the normalized value reflected in the Tracking_Value property of the lighting output shall occur when the Lighting_Command property is written with a ramp request that does not include a ramp-rate value. The range of allowable ramp-rate values is 0.1 %/s to 100.0 %/s inclusive.
A propriedade defaultRampRate do objeto lightingOutput pode ser lida e escrita utilizando um tag normal (IOTag).
lightingOutput-<endereçoDoObjeto>.defaultRampRate |
<tipo> = 54 |
<propriedade> = 375 |
Um numero em ponto flutuante de 32 bits.
