lightingOutput.defaultFadeTime |
Indicates the amount of time in milliseconds over which changes to the normalized value reflected in the Tracking_Value property of the lighting output shall occur when the Lighting_Command property is written with a fade request that does not include a fade-time value. The range of allowable fade-time values is 100 ms to 86400000 ms (1 day) inclusive.
A propriedade defaultFadeTime do objeto lightingOutput pode ser lida e escrita utilizando um tag normal (IOTag).
lightingOutput-<endereçoDoObjeto>.defaultFadeTime |
<tipo> = 54 |
<propriedade> = 374 |
