Objeto accessCredential
Defines a standardized object whose properties represent the externally visible characteristics of a credential that is used for authentication and authorization when requesting access. The credential can be owned by an access user of any type. Access user ownership is represented by a reference to an Access User object.
Objetos do tipo accessCredential possuem as seguintes propriedades:
•absenteeLimit
•activationTime
•assignedAccessRights
•authenticationFactors
•authorizationExemptions
•belongsTo
•credentialDisable
•credentialStatus
•daysRemaining
•description
•expirationTime
•extendedTimeEnable
•globalIdentifier
•lastAccessEvent
•lastAccessPoint
•lastUseTime
•objectIdentifier
•objectName
•objectType
•profileLocation
•profileName
•propertyList
•reasonForDisable
•reliability
•reliabilityEvaluationInhibit
•statusFlags
•tags
•threatAuthority
•traceFlag
•usesRemaining
