accessCredential.traceFlag |
Specifies whether the credential is being traced. When a traced credential is used at an access point, the Access_Event property of the corresponding Access Point object shall be set to TRACE.
A propriedade traceFlag do objeto accessCredential pode ser lida e escrita utilizando um tag normal (IOTag).
accessCredential-<endereçoDoObjeto>.traceFlag |
<tipo> = 32 |
<propriedade> = 308 |
