accessCredential.authenticationFactors |
Specifies the authentication factors that belong to this credential. Any access attempt using an authentication factor which is disabled shall fail. In this case, the Access_Event property of the Access Point object where this authentication factor was used shall be set to the value corresponding to the reason why it was disabled.
A propriedade authenticationFactors do objeto accessCredential pode ser lida e escrita utilizando um tag normal (IOTag).
accessCredential-<endereçoDoObjeto>.authenticationFactors |
<tipo> = 32 |
<propriedade> = 257 |
Um string contendo um XML com um valor do tipo <SequenceOfBACnetCredentialAuthenticationFactor>.
