accessCredential.extendedTimeEnable |
Specifies which command of type BACnetDoorValue shall be used to command the access door when access is granted. If extended time is enabled (TRUE), EXTENDED_PULSE_UNLOCK is used, otherwise (FALSE) PULSE_UNLOCK is used.
A propriedade extendedTimeEnable do objeto accessCredential pode ser lida e escrita utilizando um tag normal (IOTag).
accessCredential-<endereçoDoObjeto>.extendedTimeEnable |
<tipo> = 32 |
<propriedade> = 271 |
