pulseConverter Object
Defines a standardized object that represents a process whereby ongoing measurements made of some quantity, such as electric power or water or natural gas usage, and represented by pulses or counts, might be monitored over some time interval for applications such as peak load management, where it is necessary to make periodic measurements but where a precise accounting of every input pulse or count is not required.
Objects of type pulseConverter have the following properties:
•ackedTransitions
•adjustValue
•count
•countBeforeChange
•countChangeTime
•covIncrement
•covPeriod
•deadband
•description
•eventAlgorithmInhibit
•eventAlgorithmInhibitRef
•eventDetectionEnable
•eventEnable
•eventMessageTexts
•eventMessageTextsConfig
•eventState
•eventTimeStamps
•highLimit
•inputReference
•limitEnable
•lowLimit
•notificationClass
•notifyType
•objectIdentifier
•objectName
•objectType
•outOfService
•presentValue
•profileLocation
•profileName
•propertyList
•reliability
•reliabilityEvaluationInhibit
•scaleFactor
•statusFlags
•tags
•timeDelay
•timeDelayNormal
•units
•updateTime
