pulseConverter.deadband |
Specifies a range between the highLimit and lowLimit properties, which the presentValue must remain within for a TO-NORMAL event to be generated.
Property deadband of object pulseConverter can be read and written using a single IOTag.
pulseConverter-<objectAddress>.deadband |
<type> = 24 |
<property> = 25 |
A 32-bit floating point number.
