pulseConverter.covPeriod |
Indicates the amount of time in seconds between the periodic COV notifications performed by this object.
Property covPeriod of object pulseConverter can be read and written using a single IOTag.
pulseConverter-<objectAddress>.covPeriod |
<type> = 24 |
<property> = 180 |
A 32-bit unsigned integer.
