pulseConverter.eventEnable |
Property eventEnable of object pulseConverter can be read and written using a block tag with 3 elements.
pulseConverter-<objectAddress>.eventEnable |
Size |
3 elements |
B1: |
B2: |
<type> = 24 |
B3: |
B4: |
<property> = 35 |
3 elements |
Index |
Name |
Type |
0 |
toOffnormal |
1 |
toFault |
2 |
toNormal |
