pulseConverter.lowLimit |
Specifies a limit that the presentValue must fall below before an event is generated.
Property lowLimit of object pulseConverter can be read and written using a single IOTag.
pulseConverter-<objectAddress>.lowLimit |
<type> = 24 |
<property> = 59 |
A 32-bit floating point number.
