pulseConverter.count |
Indicates the count of the input pulses as acquired from the physical input or the property referenced by the Input_Reference property.
Property count of object pulseConverter can be read and written using a single IOTag.
pulseConverter-<objectAddress>.count |
<type> = 24 |
<property> = 177 |
A 32-bit unsigned integer.
