pulseConverter.outOfService |
Indicates weather (TRUE) or not (FALSE) the physical input that the object represents is not in service.
Property outOfService of object pulseConverter can be read and written using a single IOTag.
pulseConverter-<objectAddress>.outOfService |
<type> = 24 |
<property> = 81 |
