pulseConverter.adjustValue |
Adjusts the Occupancy_Count property when written. When this property is written and the value of the Occupancy_Count_Enable property is FALSE, then the Adjust_Value property shall be set to zero. If Adjust_Value has never been written or the Occupancy_Count_Enable property is FALSE, then this property shall have a value of zero.
Property adjustValue of object pulseConverter can be read and written using a single IOTag.
pulseConverter-<objectAddress>.adjustValue |
<type> = 24 |
<property> = 176 |
A 32-bit floating point number.
