pulseConverter.countBeforeChange |
Indicates the value of the Count property just prior to the most recent write to the Adjust_Value property. If no such write has yet occurred, this property shall have the value zero.
Property countBeforeChange of object pulseConverter can be read and written using a single IOTag.
pulseConverter-<objectAddress>.countBeforeChange |
<type> = 24 |
<property> = 178 |
A 32-bit unsigned integer.
