pulseConverter.scaleFactor |
Provides the conversion factor for computing Present_Value. It represents the change in Present_Value resulting from changing the value of Count by one.
Property scaleFactor of object pulseConverter can be read and written using a single IOTag.
pulseConverter-<objectAddress>.scaleFactor |
<type> = 24 |
<property> = 188 |
A 32-bit floating point number.
