BACnetTimeStamp
BACnetTimeStamp
Esta representação de dados complexos via XML é utilizada pelos seguintes objetos/propriedades:
•accessDoor.commandTimeArray
•accessDoor.eventTimeStamps
•accessDoor.lastCommandTime
•accessPoint.accessEventTime
•accessPoint.eventTimeStamps
•accessZone.eventTimeStamps
•accumulator.eventTimeStamps
•alertEnrollment.eventTimeStamps
•analogInput.eventTimeStamps
•analogOutput.commandTimeArray
•analogOutput.eventTimeStamps
•analogOutput.lastCommandTime
•analogValue.commandTimeArray
•analogValue.eventTimeStamps
•analogValue.lastCommandTime
•binaryInput.eventTimeStamps
•binaryLightingOutput.commandTimeArray
•binaryLightingOutput.eventTimeStamps
•binaryLightingOutput.lastCommandTime
•binaryOutput.commandTimeArray
•binaryOutput.eventTimeStamps
•binaryOutput.lastCommandTime
•binaryValue.commandTimeArray
•binaryValue.eventTimeStamps
•binaryValue.lastCommandTime
•bitstringValue.commandTimeArray
•bitstringValue.eventTimeStamps
•bitstringValue.lastCommandTime
•channel.eventTimeStamps
•characterstringValue.commandTimeArray
•characterstringValue.eventTimeStamps
•characterstringValue.lastCommandTime
•command.eventTimeStamps
•credentialDataInput.eventTimeStamps
•credentialDataInput.updateTime
•dateValue.commandTimeArray
•dateValue.eventTimeStamps
•dateValue.lastCommandTime
•datepatternValue.commandTimeArray
•datepatternValue.eventTimeStamps
•datepatternValue.lastCommandTime
•datetimeValue.commandTimeArray
•datetimeValue.eventTimeStamps
•datetimeValue.lastCommandTime
•datetimepatternValue.commandTimeArray
•datetimepatternValue.eventTimeStamps
•datetimepatternValue.lastCommandTime
•device.eventTimeStamps
•device.lastRestoreTime
•device.timeOfDeviceRestart
•escalator.eventTimeStamps
•eventEnrollment.eventTimeStamps
•eventLog.eventTimeStamps
•globalGroup.eventTimeStamps
•integerValue.commandTimeArray
•integerValue.eventTimeStamps
•integerValue.lastCommandTime
•largeAnalogValue.commandTimeArray
•largeAnalogValue.eventTimeStamps
•largeAnalogValue.lastCommandTime
•lifeSafetyPoint.eventTimeStamps
•lifeSafetyZone.eventTimeStamps
•lift.eventTimeStamps
•lightingOutput.commandTimeArray
•lightingOutput.lastCommandTime
•loadControl.eventTimeStamps
•loop.eventTimeStamps
•multiStateInput.eventTimeStamps
•multiStateOutput.commandTimeArray
•multiStateOutput.eventTimeStamps
•multiStateOutput.lastCommandTime
•multiStateValue.commandTimeArray
•multiStateValue.eventTimeStamps
•multiStateValue.lastCommandTime
•networkPort.eventTimeStamps
•notificationClass.eventTimeStamps
•octetstringValue.commandTimeArray
•octetstringValue.lastCommandTime
•positiveIntegerValue.commandTimeArray
•positiveIntegerValue.eventTimeStamps
•positiveIntegerValue.lastCommandTime
•program.eventTimeStamps
•pulseConverter.eventTimeStamps
•schedule.eventTimeStamps
•timeValue.commandTimeArray
•timeValue.eventTimeStamps
•timeValue.lastCommandTime
•timepatternValue.commandTimeArray
•timepatternValue.eventTimeStamps
•timepatternValue.lastCommandTime
•timer.eventTimeStamps
•trendLog.eventTimeStamps
•trendLogMultiple.eventTimeStamps
Esquema XML
  <xs:complexType name="BACnetTimeStamp">
    <xs:sequence>
      <xs:choice>
        <xs:element name="Time" type="Time" />
        <xs:element name="SequenceNumber" type="Unsigned" />
        <xs:element name="Datetime" type="BACnetDateTime" />
      </xs:choice>
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="BACnetTimeStamp" />
</xs:schema>
Exemplos
Exemplo 1:
  <BACnetTimeStamp>
    <Time>22:39:15.980</Time>
  </BACnetTimeStamp>
</Value>
Exemplo 2:
  <BACnetTimeStamp>
    <SequenceNumber>1235</SequenceNumber>
  </BACnetTimeStamp>
</Value>
Exemplo 3:
  <BACnetTimeStamp>
    <Datetime>
      <Date>2019-12-20</Date>
    </Datetime>
  </BACnetTimeStamp>
</Value>
