Objeto channel
Objeto channel
defines a standardized object used to forward a single received value to a collection of object properties. The collection of object properties may include any combination of object types, as well as properties of different data types. Each Channel object is associated with a single logical "channel" in the range 0..65535. Multiple Channel object instances may be associated with a given channel number. Each Channel object may be a member of zero or more "control groups" to facilitate writing to Channel objects with the WriteGroup service. The Channel object is intended for value distribution and does not maintain a state. Therefore, it does not act on its own and does not contain a priority array. When the Present_Value property of this object is written by the WriteProperty, WritePropertyMultiple, or WriteGroup services, and a 'Priority' is provided in the write, this object shall use this same priority to command the referenced properties.
Objetos do tipo channel possuem as seguintes propriedades:
•ackedTransitions
•allowGroupDelayInhibit
•channelNumber
•controlGroups
•description
•eventDetectionEnable
•eventEnable
•eventMessageTexts
•eventMessageTextsConfig
•eventState
•eventTimeStamps
•executionDelay
•lastPriority
•listOfObjectPropertyReferences
•notificationClass
•notifyType
•objectIdentifier
•objectName
•objectType
•outOfService
•presentValue
•profileLocation
•profileName
•propertyList
•reliability
•reliabilityEvaluationInhibit
•statusFlags
•tags
•valueSource
•writeStatus
