channel.allowGroupDelayInhibit |
Indicates whether WriteGroup service writes to this object, that specify 'Inhibit Delay'=TRUE, may override any execution delay specified in this object. Execution_Delay shall always occur as the result of WriteProperty or WritePropertyMultiple. In the case of WriteGroup, Execution_Delay shall always occur unless the WriteGroup service parameter 'Inhibit Delay' is TRUE, and the Channel object property Allow_Group_Delay_Inhibit is present and has the value TRUE.
A propriedade allowGroupDelayInhibit do objeto channel pode ser lida e escrita utilizando um tag normal (IOTag).
channel-<endereçoDoObjeto>.allowGroupDelayInhibit |
<tipo> = 53 |
<propriedade> = 365 |
