channel.lastPriority |
Conveys the priority at which the Present_Value was most recently written (1..16). If an attempt was made to write to the Present_Value without the 'Priority' parameter, a default priority of 16 (the lowest priority) shall be assumed. The initial value of Last_Priority shall be 16.
A propriedade lastPriority do objeto channel pode ser lida e escrita utilizando um tag normal (IOTag).
channel-<endereçoDoObjeto>.lastPriority |
<tipo> = 53 |
<propriedade> = 369 |
