Objeto largeAnalogValue
Defines a standardized object whose properties represent the externally visible characteristics of a named data value in a BACnet device. A BACnet device can use a Large Analog Value object to make any kind of double-precision data value accessible to other BACnet devices. The mechanisms by which the value is derived are not visible to the BACnet client.
Objetos do tipo largeAnalogValue possuem as seguintes propriedades:
•ackedTransitions
•commandTimeArray
•covIncrement
•currentCommandPriority
•deadband
•description
•eventAlgorithmInhibit
•eventAlgorithmInhibitRef
•eventDetectionEnable
•eventEnable
•eventMessageTexts
•eventMessageTextsConfig
•eventState
•eventTimeStamps
•faultHighLimit
•faultLowLimit
•highLimit
•lastCommandTime
•limitEnable
•lowLimit
•maxPresValue
•minPresValue
•notificationClass
•notifyType
•objectIdentifier
•objectName
•objectType
•outOfService
•presentValue
•priorityArray
•profileLocation
•profileName
•propertyList
•reliability
•reliabilityEvaluationInhibit
•relinquishDefault
•resolution
•statusFlags
•tags
•timeDelay
•timeDelayNormal
•units
•valueSource
•valueSourceArray
