BACnetDateTime
BACnetDateTime
This XML representation of complex data is used by the following objects/properties:
•accessCredential.activationTime
•accessCredential.expirationTime
•accessCredential.lastUseTime
•accessDoor.priorityArray
•accessZone.lastCredentialAddedTime
•accessZone.lastCredentialRemovedTime
•accumulator.loggingRecord
•accumulator.valueChangeTime
•analogOutput.priorityArray
•analogValue.priorityArray
•averaging.maximumValueTimestamp
•averaging.minimumValueTimestamp
•binaryInput.changeOfStateTime
•binaryInput.timeOfActiveTimeReset
•binaryInput.timeOfStateCountReset
•binaryLightingOutput.priorityArray
•binaryLightingOutput.timeOfActiveTimeReset
•binaryLightingOutput.timeOfStrikeCountReset
•binaryOutput.changeOfStateTime
•binaryOutput.priorityArray
•binaryOutput.timeOfActiveTimeReset
•binaryOutput.timeOfStateCountReset
•binaryValue.changeOfStateTime
•binaryValue.priorityArray
•binaryValue.timeOfActiveTimeReset
•binaryValue.timeOfStateCountReset
•bitstringValue.priorityArray
•characterstringValue.priorityArray
•dateValue.priorityArray
•datepatternValue.priorityArray
•datetimeValue.presentValue
•datetimeValue.priorityArray
•datetimeValue.relinquishDefault
•datetimepatternValue.presentValue
•datetimepatternValue.priorityArray
•datetimepatternValue.relinquishDefault
•eventLog.startTime
•eventLog.stopTime
•file.modificationDate
•integerValue.priorityArray
•largeAnalogValue.priorityArray
•lightingOutput.priorityArray
•loadControl.startTime
•multiStateOutput.priorityArray
•multiStateValue.priorityArray
•octetstringValue.priorityArray
•positiveIntegerValue.priorityArray
•pulseConverter.countChangeTime
•pulseConverter.updateTime
•timeValue.priorityArray
•timepatternValue.priorityArray
•timer.expirationTime
•timer.stateChangeValues
•timer.updateTime
•trendLog.startTime
•trendLog.stopTime
•trendLogMultiple.startTime
•trendLogMultiple.stopTime
XML Schema
  <xs:complexType name="BACnetDateTime">
    <xs:sequence>
      <xs:element name="Date" type="Date" />
      <xs:element name="Time" type="Time" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="BACnetDateTime" />
</xs:schema>
Examples
Example 1:
  <BACnetDateTime>
    <Date>2017-12-20</Date>
    <Time>22:39:15.980</Time>
  </BACnetDateTime>
</Value>
Example 2:
  <BACnetDateTime>
    <Date>????-??-??-?</Date>
    <Time>??:??:??.???</Time>
  </BACnetDateTime>
</Value>
Example 3:
  <BACnetDateTime>
  </BACnetDateTime>
</Value>
