Time
Time
This XML representation of complex data is used by the following objects/properties:
•timer.stateChangeValues
XML Schema
  <xs:simpleType name="Time">
      <xs:pattern value="(([01][0-9]|2[0-3])|\?\?):([0-5][0-9]|\?\?):([0-5][0-9]|\?\?)(.([0-9][0-9][0-9]|\?\?\?))?" />
    </xs:restriction>
  </xs:simpleType>
  <xs:element name="Value" type="Time" />
</xs:schema>
Examples
Example 1:
  <Time>22:39:15.980</Time>
</Value>
