timer.stateChangeValues
Represents the values that are to be written to the referenced properties when a change of the timer state occurs. Each of the elements 1-7 of this array may contain a value to be written for the respective change of timer state. The array index of the element is equal to the numerical value of the BACnetTimerTransition enumeration for the respective timer state change. The timer state change NONE has no corresponding array element.
Property stateChangeValues of object timer can be read and written using a block tag with 7 elements.
Text Parameters
Property
Value
ParamDevice
<deviceAddress>
ParamItem
timer-<objectAddress>.stateChangeValues
Size
7 elements
Numeric Parameters
Property
Value
B1:
<deviceAddress>
B2:
<type> = 31
B3:
<objectAddress>
B4:
<property> = 396
Size:
7 elements
Block Elements
Index
Name
Type
0
elm00
•A null/empty value.
•An integer value, where 0 corresponds to FALSE and any other value corresponds to TRUE.
•A character string containing an XML with a value of type <Unsigned>.
•A character string containing an XML with a value of type <INTEGER>.
•A 32-bit floating point number.
•A character string containing an XML with a value of type <Double>.
•A string value representing a sequence of octets, where each octet is represented by a pair of hexadecimal characters (ex: '0F121A').
•A character string containing an XML with a value of type <CharacterString>.
•A character string containing an XML with a value of type <BitString>.
•A character string containing an XML with a value of type <Enumerated>.
•A Date/Time value (only the Date part).
•A character string containing an XML with a value of type <Time>.
•A character string containing an XML with a value of type <BACnetObjectIdentifier>.
•A character string containing an XML with a value of type <Null>.
•A character string containing an XML with a value of type <Any>.
•A character string containing an XML with a value of type <BACnetDateTime>.
•A character string containing an XML with a value of type <BACnetLightingCommand>.
1
elm01
2
elm02
3
elm03
4
elm04
5
elm05
6
elm06
