Enumerated
Enumerated
This XML representation of complex data is used by the following objects/properties:
•timer.stateChangeValues
XML Schema
  <xs:simpleType name="Enumerated">
    <xs:restriction base="xs:integer" />
  </xs:simpleType>
  <xs:element name="Value" type="Enumerated" />
</xs:schema>
Examples
Example 1:
  <Enumerated>0</Enumerated>
</Value>
