CharacterString
CharacterString
This XML representation of complex data is used by the following objects/properties:
•networkPort.bacnetIpGlobalAddress
•networkPort.fdBbmdAddress
•timer.stateChangeValues
XML Schema
  <xs:simpleType name="CharacterString">
    <xs:restriction base="xs:string" />
  </xs:simpleType>
  <xs:element name="Value" type="CharacterString" />
</xs:schema>
Examples
Example 1:
  <CharacterString>Abcde</CharacterString>
</Value>
