Double
Double
This XML representation of complex data is used by the following objects/properties:
•accessDoor.priorityArray
•analogOutput.priorityArray
•analogValue.priorityArray
•binaryLightingOutput.priorityArray
•binaryOutput.priorityArray
•binaryValue.priorityArray
•bitstringValue.priorityArray
•channel.presentValue
•characterstringValue.priorityArray
•dateValue.priorityArray
•datepatternValue.priorityArray
•datetimeValue.priorityArray
•datetimepatternValue.priorityArray
•integerValue.priorityArray
•largeAnalogValue.priorityArray
•lightingOutput.priorityArray
•multiStateOutput.priorityArray
•multiStateValue.priorityArray
•octetstringValue.priorityArray
•positiveIntegerValue.priorityArray
•timeValue.priorityArray
•timepatternValue.priorityArray
•timer.stateChangeValues
XML Schema
  <xs:simpleType name="Double">
    <xs:restriction base="xs:double" />
  </xs:simpleType>
  <xs:element name="Value" type="Double" />
</xs:schema>
Examples
Example 1:
  <Double>123456.789012</Double>
</Value>
