timepatternValue.priorityArray
Read-only array of prioritized values.
Property priorityArray of object timepatternValue can be read and written using a block tag with 16 elements.
Text Parameters
Property
Value
ParamDevice
<deviceAddress>
ParamItem
timepatternValue-<objectAddress>.priorityArray
Size
16 elements
Numeric Parameters
Property
Value
B1:
<deviceAddress>
B2:
<type> = 49
B3:
<objectAddress>
B4:
<property> = 87
Size:
16 elements
Block Elements
Index
Name
Type
0
elm00
•A null/empty value.
•A 32-bit floating point number.
•An unsigned integer representing an enumerated value.
•A character string containing an XML with a value of type <Unsigned>.
•A character string containing an XML with a value of type <Boolean>.
•A character string containing an XML with a value of type <INTEGER>.
•A character string containing an XML with a value of type <Double>.
•A Date/Time value (only the Time part).
•A string value.
•A character string containing an XML with a value of type <OctetString>.
•A character string containing an XML with a value of type <BitString>.
•A character string containing an XML with a value of type <Date>.
•A character string containing an XML with a value of type <BACnetObjectIdentifier>.
•A character string containing an XML with a value of type <Any>.
•A character string containing an XML with a value of type <BACnetDateTime>.
1
elm01
•A string value.
2
elm02
•A string value.
3
elm03
•A string value.
4
elm04
•A string value.
5
elm05
•A string value.
6
elm06
•A string value.
7
elm07
•A string value.
8
elm08
•A string value.
9
elm09
•A string value.
10
elm10
•A string value.
11
elm11
•A string value.
12
elm12
•A string value.
13
elm13
•A string value.
14
elm14
•A string value.
15
elm15
•A string value.
