accumulator.loggingRecord
List of values that must be acquired and returned 'atomically' in order to allow proper interpretation of the data.
Property loggingRecord of object accumulator can be read and written using a block tag with 4 elements.
Text Parameters
Property
Value
ParamDevice
<deviceAddress>
ParamItem
accumulator-<objectAddress>.loggingRecord
Size
4 elements
Numeric Parameters
Property
Value
B1:
<deviceAddress>
B2:
<type> = 23
B3:
<objectAddress>
B4:
<property> = 184
Size:
4 elements
Block Elements
Index
Name
Type
0
Timestamp
A Date, Null or String (Xml) value representing a BACnet date/time.
•A null value means the date/time is empty/not set;
•A date/time value representing a precise date and time;
•A character string containing an XML with a value of type <BACnetDateTime>.
1
PresentValue
A 32-bit unsigned integer.
2
AccumulatedValue
3
AccumulatorStatus
An integer representing one of the options of enumeration <BACnetAccumulatorRecord_AccumulatorStatus>.
