accessZone.lastCredentialRemovedTime
Indicates the date and time when a reference to an Access Credential object has last been removed from the Credentials_In_Zone property. If this property is present, but no credential has yet been removed, then this property shall not convey an actual time and shall contain a value of X'FF' in all octets.
Property lastCredentialRemovedTime of object accessZone can be read and written using a single IOTag.
Text Parameters
Property
Value
ParamDevice
<deviceAddress>
ParamItem
accessZone-<objectAddress>.lastCredentialRemovedTime
Numeric Parameters
Property
Value
N1:
<deviceAddress>
N2:
<type> = 36
N3:
<objectAddress>
N4:
<property> = 280
Tag Value
A Date, Null or String (Xml) value representing a BACnet date/time.
•A null value means the date/time is empty/not set;
•A date/time value representing a precise date and time;
•A character string containing an XML with a value of type <BACnetDateTime>.
