datetimeValue.presentValue
Indicates the current value of the object.
Property presentValue of object datetimeValue can be read and written using a single IOTag.
Text Parameters
Property
Value
ParamDevice
<deviceAddress>
ParamItem
datetimeValue-<objectAddress>.presentValue
Numeric Parameters
Property
Value
N1:
<deviceAddress>
N2:
<type> = 44
N3:
<objectAddress>
N4:
<property> = 85
Tag Value
A Date, Null or String (Xml) value representing a BACnet date/time.
•A null value means the date/time is empty/not set;
•A date/time value representing a precise date and time;
•A character string containing an XML with a value of type <BACnetDateTime>.
