eventEnrollment.eventParameters
Provides the parameter values needed for the algorithm configured in eventType.
Property eventParameters of object eventEnrollment can be read and written using a single IOTag.
Text Parameters
Property
Value
ParamDevice
<deviceAddress>
ParamItem
eventEnrollment-<objectAddress>.eventParameters
Numeric Parameters
Property
Value
N1:
<deviceAddress>
N2:
<type> = 9
N3:
<objectAddress>
N4:
<property> = 83
Tag Value
•A character string containing an XML with a value of type <BACnetEventParameter_ChangeOfBitstring>.
•A character string containing an XML with a value of type <BACnetEventParameter_ChangeOfState>.
•A character string containing an XML with a value of type <BACnetEventParameter_ChangeOfValue>.
•A character string containing an XML with a value of type <BACnetEventParameter_CommandFailure>.
•A character string containing an XML with a value of type <BACnetEventParameter_FloatingLimit>.
•A character string containing an XML with a value of type <BACnetEventParameter_OutOfRange>.
•A character string containing an XML with a value of type <BACnetEventParameter_ChangeOfLifeSafety>.
•A character string containing an XML with a value of type <BACnetEventParameter_Extended>.
•A character string containing an XML with a value of type <BACnetEventParameter_BufferReady>.
•A character string containing an XML with a value of type <BACnetEventParameter_UnsignedRange>.
•A character string containing an XML with a value of type <BACnetEventParameter_AccessEvent>.
•A character string containing an XML with a value of type <BACnetEventParameter_DoubleOutOfRange>.
•A character string containing an XML with a value of type <BACnetEventParameter_SignedOutOfRange>.
•A character string containing an XML with a value of type <BACnetEventParameter_UnsignedOutOfRange>.
•A character string containing an XML with a value of type <BACnetEventParameter_ChangeOfCharacterstring>.
•A character string containing an XML with a value of type <BACnetEventParameter_ChangeOfStatusFlags>.
•A null/empty value.
•A character string containing an XML with a value of type <BACnetEventParameter_ChangeOfDiscreteValue>.
•A character string containing an XML with a value of type <BACnetEventParameter_ChangeOfTimer>.
