BACnetEventParameter_CommandFailure
This XML representation of complex data is used by the following objects/properties:
•eventEnrollment.eventParameters
XML Schema
  <xs:complexType name="BACnetEventParameter_CommandFailure">
    <xs:sequence>
      <xs:element name="TimeDelay" type="Unsigned" />
      <xs:element name="FeedbackPropertyReference" type="BACnetDeviceObjectPropertyReference" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="BACnetEventParameter_CommandFailure" />
</xs:schema>
Examples
Example 1:
  <BACnetEventParameter_CommandFailure>
    <TimeDelay>1234</TimeDelay>
    <FeedbackPropertyReference>
      <ObjectIdentifier>device-502</ObjectIdentifier>
      <PropertyIdentifier>action</PropertyIdentifier>
      <PropertyArrayIndex>1237</PropertyArrayIndex>
      <DeviceIdentifier>device-505</DeviceIdentifier>
    </FeedbackPropertyReference>
  </BACnetEventParameter_CommandFailure>
</Value>
