BACnetEventParameter_DoubleOutOfRange
This XML representation of complex data is used by the following objects/properties:
•eventEnrollment.eventParameters
XML Schema
  <xs:complexType name="BACnetEventParameter_DoubleOutOfRange">
    <xs:sequence>
      <xs:element name="TimeDelay" type="Unsigned" />
      <xs:element name="LowLimit" type="Double" />
      <xs:element name="HighLimit" type="Double" />
      <xs:element name="Deadband" type="Double" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="BACnetEventParameter_DoubleOutOfRange" />
</xs:schema>
Examples
Example 1:
  <BACnetEventParameter_DoubleOutOfRange>
    <TimeDelay>1234</TimeDelay>
    <LowLimit>123457.789012</LowLimit>
    <HighLimit>123458.789012</HighLimit>
    <Deadband>123459.789012</Deadband>
  </BACnetEventParameter_DoubleOutOfRange>
</Value>
