BACnetEventParameter_ChangeOfState
This XML representation of complex data is used by the following objects/properties:
•eventEnrollment.eventParameters
XML Schema
  <xs:complexType name="BACnetEventParameter_ChangeOfState">
    <xs:sequence>
      <xs:element name="TimeDelay" type="Unsigned" />
      <xs:element name="ListOfValues" type="SequenceOfBACnetPropertyStates" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="BACnetEventParameter_ChangeOfState" />
</xs:schema>
Examples
Example 1:
  <BACnetEventParameter_ChangeOfState>
    <TimeDelay>1234</TimeDelay>
    <ListOfValues />
  </BACnetEventParameter_ChangeOfState>
</Value>
Example 2:
    <TimeDelay>1235</TimeDelay>
    <ListOfValues>
      <BACnetPropertyStates>
        <BooleanValue>true</BooleanValue>
      </BACnetPropertyStates>
    </ListOfValues>
</Value>
