BACnetEventParameter_ChangeOfBitstring
This XML representation of complex data is used by the following objects/properties:
•eventEnrollment.eventParameters
XML Schema
  <xs:complexType name="BACnetEventParameter_ChangeOfBitstring">
    <xs:sequence>
      <xs:element name="TimeDelay" type="Unsigned" />
      <xs:element name="Bitmask" type="BitString" />
      <xs:element name="ListOfBitstringValues" type="SequenceOfBitString" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="BACnetEventParameter_ChangeOfBitstring" />
</xs:schema>
Examples
Example 1:
  <BACnetEventParameter_ChangeOfBitstring>
    <TimeDelay>1234</TimeDelay>
    <Bitmask>101</Bitmask>
    <ListOfBitstringValues />
  </BACnetEventParameter_ChangeOfBitstring>
</Value>
Example 2:
    <TimeDelay>1235</TimeDelay>
    <ListOfBitstringValues>
      <BitString>101</BitString>
      <BitString>1</BitString>
    </ListOfBitstringValues>
</Value>
