SequenceOfBitString
SequenceOfBitString
This XML representation of complex data is used by the following objects/properties:
•bitstringValue.alarmValues
XML Schema
  <xs:complexType name="SequenceOfBitString">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BitString" type="BitString" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBitString" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBitString />
</Value>
Example 2:
  <SequenceOfBitString>
    <BitString>101</BitString>
    <BitString>1</BitString>
  </SequenceOfBitString>
</Value>
