BACnetEventParameter_BufferReady
This XML representation of complex data is used by the following objects/properties:
•eventEnrollment.eventParameters
XML Schema
  <xs:complexType name="BACnetEventParameter_BufferReady">
    <xs:sequence>
      <xs:element name="NotificationThreshold" type="Unsigned" />
      <xs:element name="PreviousNotificationCount" type="Unsigned32" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="BACnetEventParameter_BufferReady" />
</xs:schema>
Examples
Example 1:
  <BACnetEventParameter_BufferReady>
    <NotificationThreshold>1234</NotificationThreshold>
    <PreviousNotificationCount>2346</PreviousNotificationCount>
  </BACnetEventParameter_BufferReady>
</Value>
