BACnetEventParameter_SignedOutOfRange
This XML representation of complex data is used by the following objects/properties:
•eventEnrollment.eventParameters
XML Schema
  <xs:complexType name="BACnetEventParameter_SignedOutOfRange">
    <xs:sequence>
      <xs:element name="TimeDelay" type="Unsigned" />
      <xs:element name="LowLimit" type="INTEGER" />
      <xs:element name="HighLimit" type="INTEGER" />
      <xs:element name="Deadband" type="Unsigned" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="BACnetEventParameter_SignedOutOfRange" />
</xs:schema>
Examples
Example 1:
  <BACnetEventParameter_SignedOutOfRange>
    <TimeDelay>1234</TimeDelay>
    <LowLimit>-799</LowLimit>
    <HighLimit>-798</HighLimit>
    <Deadband>1237</Deadband>
  </BACnetEventParameter_SignedOutOfRange>
</Value>
