BACnetEventParameter_ChangeOfCharacterstring
This XML representation of complex data is used by the following objects/properties:
•eventEnrollment.eventParameters
XML Schema
  <xs:complexType name="BACnetEventParameter_ChangeOfCharacterstring">
    <xs:sequence>
      <xs:element name="TimeDelay" type="Unsigned" />
      <xs:element name="ListOfAlarmValues" type="SequenceOfCharacterString" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="BACnetEventParameter_ChangeOfCharacterstring" />
</xs:schema>
Examples
Example 1:
  <BACnetEventParameter_ChangeOfCharacterstring>
    <TimeDelay>1234</TimeDelay>
    <ListOfAlarmValues />
  </BACnetEventParameter_ChangeOfCharacterstring>
</Value>
Example 2:
    <TimeDelay>1235</TimeDelay>
    <ListOfAlarmValues>
      <CharacterString>Abcde</CharacterString>
    </ListOfAlarmValues>
</Value>
