SequenceOfCharacterString
This XML representation of complex data is used by the following objects/properties:
•accessPoint.authenticationPolicyNames
•bitstringValue.bitText
•command.actionText
•globalGroup.groupMemberNames
•lift.carDoorText
•lift.floorText
•loadControl.shedLevelDescriptions
•multiStateInput.stateText
•multiStateOutput.stateText
•multiStateValue.stateText
•structuredView.subordinateAnnotations
XML Schema
  <xs:complexType name="SequenceOfCharacterString">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="CharacterString" type="CharacterString" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfCharacterString" />
</xs:schema>
Examples
Example 1:
  <SequenceOfCharacterString />
</Value>
Example 2:
  <SequenceOfCharacterString>
    <CharacterString>Abcde</CharacterString>
  </SequenceOfCharacterString>
</Value>
