structuredView.subordinateAnnotations |
Used to define a text string description for each member of the Subordinate_List. The content of these strings is not restricted. If the size of this array is changed, the size of the Subordinate_List, Subordinate_Tags, Subordinate_Relationships, and Subordinate_Node_Types arrays shall also be changed to the same size.
Property subordinateAnnotations of object structuredView can be read and written using a single IOTag.
structuredView-<objectAddress>.subordinateAnnotations |
<type> = 29 |
<property> = 210 |
A character string containing an XML with a value of type <SequenceOfCharacterString>.
