accessPoint.authenticationPolicyNames |
Specifies the names of the defined authentication policies.
Property authenticationPolicyNames of object accessPoint can be read and written using a single IOTag.
accessPoint-<objectAddress>.authenticationPolicyNames |
<type> = 33 |
<property> = 259 |
A character string containing an XML with a value of type <SequenceOfCharacterString>.
