loadControl.shedLevelDescriptions |
Represents a description of the shed levels that the Load Control object can take on. This allows a local configuration tool to provide to a user an understanding of what each shed level in this Load Control object's load shedding algorithm will do. The level at which each shed action will occur can then be configured by writing to the Shed_Levels property.
Property shedLevelDescriptions of object loadControl can be read and written using a single IOTag.
loadControl-<objectAddress>.shedLevelDescriptions |
<type> = 28 |
<property> = 220 |
A character string containing an XML with a value of type <SequenceOfCharacterString>.
