command.actionText |
Used to indicate a text string description for each of the possible values of the presentValue property.
Property actionText of object command can be read and written using a single IOTag.
command-<objectAddress>.actionText |
<type> = 7 |
<property> = 3 |
A character string containing an XML with a value of type <SequenceOfCharacterString>.
