Common Properties
Common Properties
This section contains information about the common properties of all Screen objects. Properties on this section do not apply to the ActiveX (MSForms), E3Chart, E3Browser, and E3Alarm objects. These objects are described later, on their specific chapters.
NOTES
Elipse E3 uses the Himetric system to define coordinates and widths. In this system, each logical unit is equivalent to a thousandth of a centimeter, that is, 1,000 units are equivalent to one centimeter. Thus, this is the standard adopted when describing Elipse E3 properties, when applicable.
The next properties are common to all previously cited objects, including Groups of objects and Dynamic Move and Rotate.
The available properties on this section are the following:
Angle
BackgroundColor
BackgroundStyle
BorderColor
BorderStyle
BorderWidth
Effect3D
Effect3D_X
Effect3D_Y
Effect3DColorBase
Effect3DColorTop
Enabled
FillStyle
ForegroundColor
Frame
GradientStyle
HasFocus
Height
HorizontalFillStyle
HorizontalPercentFill
MouseOver
MouseOverChild
Screen
Shadow
ShadowColor
ShadowX
ShadowY
TabStop
Tip
VerticalFillStyle
VerticalPercentFill
Visible
Width
X
Y
