Specifies a fill color for an object's shadow. This color is used when the Shadow property is set to True. In scripts, use VBScript's RGB method to create a color to link to this property. Default value of this property is dark gray (RGB(128, 128, 128)).
Feedback
Would you like to provide more information about your experience in this site?
